My running lights at the top of the MH in front are not working. The ones in the back do. I can't locate a fuse specifically listed for that. Any suggestions on the reason? :h
Gary, the front and rear clearance lights, the side marker lights if you have them, and the headlights are probably on the same circuit. Have you tried the headlights? If so, there will be a fuse for the above in the compartment with all the other 12 VDC circuits. That's where I'd start.
