dougrainer
May 30, 2020Nomad
The refer elements do NOT draw 12 volt DC power. 1200 models have 2 AC elements and they pull 1.7 amps AC EACH for a draw of 3.4 amps AC. That is 408 WATTS AC . Your Inverter has MORE than enough power to run the AC elements and it will not cause failures of Alternators. If you have premature failure of Alternators, something else is causing it. 7 years and 50k sounds like a good run for an Alternator on a Diesel motorhome. Doug
38,769 PostsLatest Activity: Jul 09, 2020
