weathershak
Nov 05, 2013Explorer
Have had luck soaking the valves with a product called PB Blaster. Heat the valve and cyl/ caliper around valve. Put an ice cube on valve to rapidly cool it, then cross your fingers. I would stick with the Dot 3 fluid. Do some research on it before you go with Dot 5. Best of luck.
38,780 PostsLatest Activity: Jul 04, 2015
