jwmII wrote:
Check out Eastwood the car resto materials supplier. They have a
product called Por-15 , and the associated materials that are suggested you use with it. Follow the directions on these items and it will be a long time before you will have to go there again.
Chassis Saver is pretty much the same as POR-15, I've used both. Just used Chassis Saver on our 2003 Adventurer. Not a lot of rust, some compartments had none but thought I'd take care of it before it got worse.
The local AutoValue carries Chassis Saver. Like POR-15, it goes a long way so if you try it, start with a small can, like a pint.
