tobydad wrote:
...Brown water drips usually indicates wood that is soaking wet or rotting...
Correct. Many refer to the brown water as "coffee."
If you can rig up a furnace blower, you can pressure test your coach. The idea is to pressurize the interior a little. Then spray soap solution around seams, joints, etc. from outside. Bubbles there will show you the Source of the Leak. Looking inside shows were the Leak found a place to drip off of.
Yes, your A/C could require a little snugging of the four fasteners that hold it to the roof. You can see them when you take the interior trim off the ceiling. SNUG!!! You'll bend the A/C or compress the roof if you over tighten.
