I will say this. there are two different standards of performance and a mistake many make
"My king outperformed my Winegard" is blatently false. as the other poster said that never happens. THey are at best half the antenna the Winegard is AT BEST.
But when you replaced the head,, did you replace teh coax which had become defective due to the effects of UV light (Sunlight)? If so the COAX may be the big difference.
The one case where the Jack will outperform a Sensar is if you are like 10 miles from the transmitters and they are scattered in a wide arc.
The Sensar is more directional, and thus may exclude the ends of the arc, where as the JACK being less directional sees a wider arc, but at 25+ miles the Jack sees .. Well wher eI"m at I have 3 times the reception JACK users have.
Antennas are like field/opera glasses
Imagine being in the Gods (The nosebleed seats in a big theater,,,been there) you look at the stage and see a bunch of 2 legged ants running around (The Phantom and Christine and so on) You break out your OPERA blasses (low power bionaculars) Now you can see people but they are a long way off. Also you can still see the full stage.
You break out the FIELD GLASSES (Full power bionaculars0 now you can no longer see all the stage but it's like you are in about row 5 or there abouts on the main floor.
Same with antennas
Omni antenna.. that's the naked eye
Jack is Opera Glasses
Sensar IV or either the II or III with wingman.. FIELD glasses.
Add the sensar pro and it's light amplifying field glasses (military type).
