MitchF150
Jul 15, 2018Nomad
It does not matter where the source of the water is coming from.. It all goes thru the same plumbing system to the faucets.
When you filled the water tank, did the water pump just start running when you were not running any water at all?
It's now time to get in and check all the lines. Sounds like a leak in the lines for sure.
Good luck!
Mitch
Good luck!
Mitch
38,773 PostsLatest Activity: Apr 22, 2026
