stickdog
Jul 15, 2018Explorer
Did you have a pressure regulator on the fill hose. High pressure can blowout RV plumbing fittings.
Did you leave the pump turned on after filling the tank, you kept pressure on the supply lines? If yes that is why it continued to leak. You need to dry the floor and then turn on the pump and then watch where the area that the water is leaking from. You have to find the leak before you can repair it.
A thirty year old coach will have a grey plastic water supply unless it has been replaced.
38,773 PostsLatest Activity: Apr 22, 2026
