alliemac9
Jan 07, 2018Explorer
RV Garage Construction - Any Tips?
I'm in the planning stages for an RV garage. I have a relatively short Class C, but would prefer to future-proof this structure (hence asking in the Class A area).
Anyone done this? Have any recommendations for resources or input on any of the following? Is there a better area on this forum to discuss this?
-Door size? (hoping to do 12'W x 14'H)
-Length? (thinking 45-50')
-Width? (I have more restrictions here due to setbacks, may be limited to approximately 15' - not ideal, but still excited to have indoor storage onsite)
-Slab construction? (6" reinforced w/rebar?)
-Insulation considerations to keep garage above freezing?
-Heater type?
-Dump station? (don't know if this is possible re: code)
-Ceiling height/style?
-Drain? (floor or trench? is this a must have?)
-RV outlet - how best to implement? I would want to put a 50A plug, but I only need 30A. Is there a way to have both plugs but only one functional at a given time, so it's only one 50A circuit versus two separate circuits? Or maybe I should do two separate so I have a guest outlet in the event of a moochdocking friend? Any resources for the electrician? I've heard of people ending up with their plug wired for 220V like a dryer instead of 110V the RV needs - want to ensure the electrician is 100% clear.
I'm currently planning on frame construction attached to the existing two-car garage. Have two current stretch goals, if you will, that may or may not be implemented based on cost/budget considerations. These include:
-Rooftop deck on back half of garage
-Laundry hookups (this is also future-proofing...the house is a ranch with laundry in the basement; if I could at least plumb it into garage I would have total single floor living if my knees ever give out on me - this may also offer options for a clean out that doubles as a dump station?)
Any insight appreciated!
-Heater type?
