rgatijnet1
Jan 08, 2018Explorer III
6" slab with rigid foam insulation underneath.
Don't know what you have for fuel so you may want to think of electric heating with the wiring in the slab.
Wall mounted AC units for Summer.
Frame construction with spray foam insulation. Painted drywall for sidewalls. Exterior to match existing house.
Truss roof frame with steel roof that snow will slide off of.
50 amp service and LED lighting.
14 x 14 roll up door with a 3 x 7 man door as well.
Level floor with a 1" lip at the door to prevent rain from blowing in.
Possibly connect to sewer or septic tank for waste disposal.
Fresh water available to fill tanks.
120 volt outlets around sidewalls.
