DutchmenSport
Jan 08, 2018Explorer
Simple. Go as BIG with everything as zoning, space, and finances will allow. You'll never have regrets going bigger with more storage space and room. Never.
About your electric hook-up? Why not just install both 30 amp and 50 amp. At least run the wire for both and have them available for hook-up. Actually, a 30 amp RV plug can easily be switched over to a normal 30 amp household plug at any time if the day comes you no longer need the 30 amp RV hook-up. You can also switch the 30 amp hook up to a different outlet, for example, for a welder if this is in your future. The wire is 30 amp serviceable, the plug used can be for anything anything that's 30 amp or less. Run the wire for both and at least you've got them available for future needs.
