NEOK
Jan 08, 2018Explorer
My RV garage is 30'x35' with two overhead doors. One door is 10'x10' for my boat the other is 10'x14' for my truck camper. The ceiling is 16'. If I had it to do over I would definitely go with 12' wide doors.That 10' door gets pretty narrow when I back in the boat of truck camper. I insulated the walls with fiberglass batts and the ceiling is blown in insulation. It is well insulated and without any heat I have never seen the temperature below about 40 degrees inside (located in northeast Oklahoma). I wired in a 30 amp RV receptacle but used wire with a heavy enough gauge that it could be changed to a 50 amp receptacle if desired in the future. I did not install a sewer dump inside but I have a clean out about 3 feet from the driveway so it's easy to dump before putting the camper in the garage.
