If you were to build a RV garage , would you make it wide enough to open slides while housed inside. Also How wide would you make it. I own older rv no slides, so I' am looking at overall needs of gar...
All good advice. However, if you have the room, I would go minimum of 50 foot long and a minimum 14 foot tall door. RESALE!!! Someone with a 45 foot coach will use every inch. Would be happy to send along some photos. Ours is wide enough inside to open all slides, pull out all storage slides and have a shop that runs the length of the garage on the "wide" side. 20 & 50 amp service inside with 20, 30 & 50 available outside. Any questions, let me know.
