If you were to build a RV garage , would you make it wide enough to open slides while housed inside. Also How wide would you make it. I own older rv no slides, so I' am looking at overall needs of gar...
Mine is 16 X 48 which is OK for my 42'... I can get around the front and back BUT I have to duck under the left slide so 18 x 52 would be better for a 45'.
By swing the door you save 2' in the height of the building. The door is made of 2x6's, insulated, and sided with Hardy plank, the same as the house. The pivots for it are 2" pipe nipples screwed into floor flanges. The bottom pipe nipple was installed in the concrete when poured.
