If you were to build a RV garage , would you make it wide enough to open slides while housed inside. Also How wide would you make it. I own older rv no slides, so I' am looking at overall needs of gar...
I built a 30x60 steel building with a 19'6" center height and a 14x14 door. The RV has been gone about 3 years but the garage/shop has gotten considerably smaller. Between the paint booth, tools, toys, bench, racks and equipment 1800 square feet fills up fast. So building a shop/garage is like buying a tool box. Buy as big as you can afford. You will use the space. Randy
