- ArchHoaglandExplorer
rgatijnet1 wrote:
The best thing to do is buy the RV and then tow a vehicle behind it. Towing a vehicle will not affect the fuel mileage that much BUT you will be getting two vehicles from point A to point B so effectively you are doubling your fuel mileage. I'm no engineer but I did stay at a Holiday Inn Express. :B
That's my thought too.
Effectively I'm getting 14 MPG by towing a toad.
I'm thinking about towing two toads and getting it up to 21 MPG...... - fourmatExplorer
10forty2 wrote:
x2
Just get the coach you want and don't concern yourself with the mpgs. They are all going to get anywhere from 4-8mpg. If you can average 6mpg, you'll be doing very well, IMHO! But honestly, if fuel mileage is going to worry you, a Class A Motorhome is probably not for you. - GoldencrazyExplorerIf fuel efficiecy is important you will have the greatest impact looking at your toad. The Ford V-10 will get in the area of 7 mpg depending on conditions. When i tow my Jeep mt toad get's 18 but when I tow my Smart Car i get 45. When i total my fuel for a month of travel my toad is the variable i can control. Sure wish i could tow my Prius 4 down. I did use dolly for awhile but a real pita.
- SnomasExplorer
donkeydew wrote:
if you have to worry about gas mileage you probably need a different hobby.
neither one will win a economy race. it is more about how the driver uses the pedal and wind/terrain. at the end of a trip will $10.or $20. really make a difference? get the one you like and enjoy it.
X2 We average 7.5 pulling a 4800# toad. Wind direction, mountains and speed all have to enter the equation. I set my cruise control on 65 about 75% of the time on the interstates.
I had a 31 ft gas safari that only got 5.5 to 6.5 mpg. It had the p30 chassis and 454 chevy engine... - rgatijnet1Explorer IIIThe best thing to do is buy the RV and then tow a vehicle behind it. Towing a vehicle will not affect the fuel mileage that much BUT you will be getting two vehicles from point A to point B so effectively you are doubling your fuel mileage. I'm no engineer but I did stay at a Holiday Inn Express. :B
- MommaluExplorerBuying a new class A motorhome its either a v10 gas or diesel pusher. Talk to enough people who own the v10 and you find it's thirsty and noisy. A friend gets a mpg difference in his v10 pick up empty or pulling his 5th wheel horse trailer at full capacity.
Our gas motorhome is pretty much the same, with a mile per gallon difference if I stay below 65 mph or choose to flow with the traffic at 72 mph. It's a reliable, thirsty, and noisy engine, we see very little difference in mpg unless there is a stiff 20mph or greater wind, then we see 6 mpg at posted hwy speeds, otherwise its 7 to 8.5 miles per gallon. Of course running with the generator on to cool the coach as you drive puts it back into the 7 mpg range.
But again if more miles per gallon is important driving a 12' tall 8' wide bread box at posted speeds IS NOT YOUR VEHICLE!
Me, I choose to remember I'm driving a 1 bedroom apartment down the road, complete with a queen bed, 3/4 bath, kitchen, furnace, A/C and I choose where I park it for the week end.
Its all how you look at it. - Chum_leeExplorer
jplante4 wrote:
wa8yxm wrote:
Major differnce is the Triton, being a Ford, is a HIGH REV engine, producing the best power curve at a much higher RPM than the low-rev GM Vortec.
This may affect engine life,. but not so much MPG.
Physics says this isn't so. A higher RPM should burn more fuel. 460 cu in of air/fuel mixture going through the motor for every RPM, 15:1 air to fuel mixture indicates that higher RPM engines will use more fuel.
I had to explain this to a co-worker who bought her first car with a manual transmission. Her father told her to keep the revs high as possible. I explained that a lower RPM is fine. When she took mt advise, she commented that she was using less gas.
Partially correct. If comparing engines of equal displacement generating equal power, usually running a higher RPM will require lower manifold pressure, cause more pumping loss, and more frictional loss than running a lower RPM with higher manifold pressure. This is not true if the engine running at lower RPM is at or near Wide Open Throttle due to mixture enrichment at WOT.
Running at a lower manifold pressure (higher vacuum) means that although the engine may be spinning faster, because its sucking less air per rev due to the lower inlet pressure, it mixes less fuel in with the air. It's a slippery slope. Every engine has its sweet spots. Cam/valve timing and port configuration is very complicated and plays a big role in fuel economy.
Chum lee - janstey58ExplorerI've had both, and both ran around 7mpg give or take. Of course wind, hills, toad, and loading all impact this.
- btilfanExplorer2005 V10 I get 8 to 10 at 60mph.
- ArchHoaglandExplorerMy 2004 Workhorse with the GM 8.1 engine has averaged 7.1 mpg over 80,000 miles of all terrains and temperatures pulling a 4,000lb toad.
That's hand calculated. I've recorded every gallon of gas I put in it.
I don't know what the cost is/was as I don't care. I keep an eye on mileage to tell me if I have a problem.
If you are worried about gas mileage don't get an RV. And don't buy any aftermarket items that claim to increase gas mileage. Snakeoil.
38,712 PostsLatest Activity: Apr 02, 2025
