valhalla360
Jan 31, 2020Navigator
How much fuel is in the tank?
If it's on "E", consider draining and disposing of the old fuel if you can get at the outlet easily.
Otherwise, you can dilute with fresh gas.
On the positive side, if it's a full tank of gas, you are less likely to get water in the fuel but be prepared to swap out filters if there is water in there.
Unless it's a really old MH, I expect it has fuel injection so the float bowl and carb jets gunking up are likely not an issue.
38,769 PostsLatest Activity: Mar 31, 2026
