Idle-Up
Sep 18, 2021Explorer
pianotuna wrote:
phemens,
The reading I've done (which may be incorrect) suggest low slow charging may be possible at -20 c (-4 f)
Tonight it will be -33c here.
Thanks for the reply - charging at freezing temperatures is incorrect as it will cause immediate un-repairable damage to the cells. If you plan on using your coach during winter, I suggest you only buy a lithium battery with an "Internal" heater. While heat- blankets will let you get by, they do not heat the cells equally which changes the capacity of the cells differently. Here's a little video I did on lithium heating:
Stay Safe Mike
https://www.youtube.com/watch?v=smCms94wH88
https://youtu.be/smCms94wH88
38,782 PostsLatest Activity: Sep 02, 2026
