Idle-Up's avatar
Idle-Up
RV Lithium Lite & Lithium Super Upgrade Systems - Mike Mas
Hello Forum Users - I just completed my 2nd “Independent” In-Depth film on upgrading an RV to Lithium Power and wanted to share it with the forum. On my most recent film, I designed two different systems for RV’s titled; "Lithium Lite" and "Lithium Super".
The “Lithium Lite” system is based on a 300 amp hour system with 3,800 watts of capacity which essentially replaces and doubles the power of most RV’s AGM batteries. This system is ideal for smaller RV’s such as B, B+ and Class C RV’s.
The "Lithium Super” is a Powerhouse System which uses a 625 amp hour battery with 8,064 watts hour capacity which allows the entire coach to be run totally on lithium power, to even include the roof air conditioner for up to 8-10 hrs at a 50% cycle. This system also offers expansion to 1250 amp hours.
My design includes moving the house batteries (now lithium) from their past “open air” compartment, where the batteries were exposed to extreme temperatures, road dust, water & salt spray, to the opposite side of the coach, to a larger sealed compartment which is temperature controlled. This compartment also houses the inverter, BMS, solar controller and battery isolator, to allow very short cable runs for near zero loss.
This unique design captures “Free Heat” generated from the inverter and a neighboring AquaHot compartment to supplement the lithium batteries internal self-heating system to provider power saving and uninterrupted operation during freezing temperatures. I hope you enjoy the film - Mike Mas
Please click on the link below for the video
https://www.youtube.com/watch?v=k2RilLqYE5c&feature=youtu.be
Seems if the link is not active - please copy and paste either links above or below - Thanks!
https://youtu.be/k2RilLqYE5c
  • Phil,
    Nice find. I'm considering 270 amp-hour SiO2--but they might be pretty heavy, so it may be best to stay with 100 amp-hour jars.
    Li doesn't have that sort of weight constraint, which is a feature I had not thought of before.
    If your information and efforts have anything to do with use of the common Group27/31 size 100AH lithium batteries in an RV, you might want to consider doubling of capacity ... without doubling of the area where the batteries are kept ... through use of these Group 31 200AH lithium batteries instead:
    https://www.lithiumion-batteries.com/products/12-volt-lithium-batteries/group-31-12v-200ah-lithium-ion-battery.php
  • Idle up,
    I'll have 7200 watt-hours of SiO2 batteries by the summer, and can use them at -40.
