Jackie_Treehorn
Feb 17, 2015Explorer
wolfe10 wrote:
NO, the PSI on the GVWR sticker (usually by the driver's area) indicates THE CORRECT/MINIMUM PRESSURE WHEN EACH AXLE IS LOADED TO ITS GAWR.
Hopefully, your actual weights will be well under GAWR and therefore the correct/minimum PSI will be less.
The 70/75 psi levels are from the GVWR sticker. You're saying that if I'm traveling with no water I would actually go lower than the 70/75?
