rk911
Feb 17, 2015Explorer
Jackie Treehorn wrote:
Winnebago suggests 70 psi for my front tires and 75 psi for the dual tires in the rear. The tire company has the fronts rated at 110 and the rears at 90. Which is the right way to air the rig up?
are you using the tire mfg load inflation table to come up with 110 and 90 or by what is stamped on the tires? the proper way is to use the minimum inflation for the load being carried. load the RV as you normally would, weigh the front and rear axles separately...at least get separate weights...and inflate as per the mfg chart.
