kaydeejay
Feb 17, 2015Explorer
More To See wrote:Wrong again! And more BS!
Let's try this again.
That tire pressure plate on your door only applies to a brand new rig straight out of the factory on day one with original tires. After that in later years it is likely meaningless.
For the vast number of older rigs running after market tires it simple can not be trusted.
But if in fact that door plate remains true for ever and ever then why not just tell any poster asking about tire pressures to just go look at their door plate.
If it's that simple then why is it that threads about tire pressure go on and on for page after page all the time.
Doesn't it always come down to "weigh each wheel" etc, etc.
Nobody ever says "go look at your door plate."
For all those out there in a rage that I suggest not to rely on those door plates I sure hope to never catch any of you looking at a tire pressure chart. On second though, why are they even published.
Regardless of Manufacturer, tires of the same size and load rating require the same pressure. So, provided the tires on the used rig are in fact the same size and load rating as the originals, the OEM pressure labels will still apply.
Did you really believe vehicle manufacturers of all types have different tire pressure values applying to different tire Manufacturers? (Assuming the same size tires)
Of course, if the tire sizes have changed, it's a whole new ball game. Then it's time to break out the load/inflation tables.
