DanTheRVMan
Feb 18, 2015Explorer
JohnnyT wrote:wolfe10 wrote:
FACT: The GVWR sticker installed by the coach manufacturer is for the OE tires (yup, they DO know what they put on there) when loaded to GAWR.
Please provide facts that are contrary to this statement.
And, no, I would never suggest any method of accurate tire pressure determination without weighting each wheel position. Then, take the heavier wheel position on each axle to determine the correct minimum PSI for all tires on that axle from your tire manufacturers inflation table.
Unlike car tires, the correct PSI for the tires on our coach (per Michelin, not me) is 70 or 110 DEPENDING ON LOAD. That is a huge range and over or under inflating is quite likely if you don't know your actual weights.
Wolfe10 is on target with his post.. I would add in addition to weight the tire pressure is determined by make and tire model, tire size and whether single or dual position.
As was pointed out know your weights, and inflate according to tire manufacturer specification for model, tire size, and tire position
JohnnyT
Your both correct, but in the real world few people weigh their MH and even fewer get 4 corner weights. If you do not have a solution using axle weights your comments are next to worthless to the guy that has to go to truck scales to weigh their MH. Truck scales are available at 90% of the places I fuel my MH.
I bump my tire pressure on the tire pressure tables 5 psi. Perfect - NO But I am not significantly under inflated either.
