Stim
Jul 31, 2018Explorer
It should have a fuel pump relay that turns on when you have oil pressure.
It will cycle the pump for a few seconds when you first turn the key on.
You need to turn the key on and off to get the pressure up.
If you listen at the tank when key is first turned on you should be able to hear the pump.
38,778 PostsLatest Activity: Jun 10, 2026
