fleetwoodjambo
Aug 02, 2018Explorer
In addition to the pump in the tank, you may have a mechanical boost pump closer to the engine underneath the driver's side, as my class C does. Alot of people, including a mechanic argued about having a second fuel pump until i showed it to him. This is because the fuel has a long way to travel from the tank to engine, not like a cars. If either one is bad (assuming you have mechanical boost pump too), could be the issue, EVEN if you can hear the pump in the tank. I would get fuel pressure checked.
38,778 PostsLatest Activity: Jun 10, 2026
