Let_s_Travel's avatar
Let_s_Travel
RV Residential Refrigerators
The class A group probably has more experience with this, since the Resi-refers are just now coming to the trailer industry. I am wondering if there are any consistent problems with having this type of refrigerator running on a pure sine inverter in the RV? Does the movement of the RV while the refer is running (going down the highway) cause shortened life of the appliance? It seems the Fivers could have more of an issue with that than the air ride class A type. I have never been a fan of the 12V RV fridge and would love to have the Resi type. So....what are your experiences? Should I opt for the big beautiful Samsung residential fridge in a new Fiver? Would appreciate your knowledge. Thanks!
  • Ivylog's avatar
    Ivylog
    Explorer III
    If my Norcold goes out again I'll replace it with a residential one and we boondock often BUT: unlike a 5er, bigger MHs come with four or more batteries and a engine alternator capable of putting 100+ amps into them.
    If you do not boondock then I do not see a problem with the lack of batteries and a 100 amp charging circuit. If you do plan on boondocking a lot then I'd go back to looking at 45' MHs and not worry about the 102" width.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    WyoTraveler wrote:
    For example, if you are driving and most of charge is going into supporting your vehicle i.e. headlight etc. there may not be much left to recharge the bank of house batteries. Solar works. Same problems occur with electric cars. You can't just drive in and fill up with electricity in a couple of minutes.
    On the grid any fridge will pretty much work.
    One of the most common complaints here in the forums from folks who went the residential route is: I get to the campground and my house batteries are dead.
    In short: Dead on sir, You are dead on.
  • Original equipment Amana side by side is still going strong in my 99 Newell. As others have said it takes sufficient battery bank to run it.
    Full Sine is better for the compressor than modified.
    A trick to use if you want to save power while on the batteries is to turn the ice maker off.
  • I dumped my Norcold 1200 LRIM last year after the second cooling unit went bad. I installed a residential refer in its place. I run the residential from my modified sine inverter and so far no problems. Regarding battery life, etc. when dry camping, the original Norcold used propane for heat, but also required a 12 volt DC source for the control board. When plugged into shore power, the Norcold used 120 volt AC, and also the 12 volt DC, again, for the control board.
    I made several test measurements on the Norcold, and then on the residential refer, and I truly believe the residential uses less power than the Norcold. The amp draw for the residential compressor is 1.8 amps which works back to 18 DC amps from the batteries. However, the residential runs infrequently and keeps the food much colder. I have actually measured the freezer at -20 degrees when cranked all the way up.
    Getting rid of the open flame and less than acceptable cooling capability with the Norcold was a big plus to me.
  • JoeH's avatar
    JoeH
    Explorer III
    We have had an all electric coach for 2 years now and have had no issues with the residential frig. With the old coach I used to go and fire up the refer a day or so before we planned to leave to cool it down. Now I turn the residential unit on a couple hours before we load up the food and drink.
    On the old propane unit I had 3 fans inside the box for air circulation and one in the flue . It always worked fine and I didn't have any issues with temps even in our hot Florida summers. I do like the huge freezer in the residential unit.
  • The sales pitch is with a large bank of batteries and using a sine wave generator you can use residential fridge off the grid. It is partly true. However, at some point in time the bank of batteries need to be charged. You need a good source of charge aside from the MH alterator. For example, if you are driving and most of charge is going into supporting your vehicle i.e. headlight etc. there may not be much left to recharge the bank of house batteries. Solar works. Same problems occur with electric cars. You can't just drive in and fill up with electricity in a couple of minutes.
  • As long as you are not dry camping the residential fridge is a better choice. It will work fine on a pure sine wave inverter while you are going down the road and plug in when you get to a campground. If you dry camp a lot like we do, then you are better off getting a gas/12/120 Norcold or a Dometic.
