SabreCanuck wrote:
From the sounds of the replies and having not really done any major research on the topic, can I assume that one shouldn't have to worry about power and/or the fridges if they were to install sufficient solar? I was thinking of solar anyway and I would assume with enough solar/battery power and the gen as a backup then power (or lack thereof) would never really be an issue would it?
I understand the factors involved and wouldn't plan on cooking a turkey in the convection microwave while on solar power but normal operation should never run out of power, would you?.
Howdy again. Well in a perfect world, 3 X 160 watt panels would more than cover the needs of running the fridge in real world situations, assuming they are flat mounted on the roof and assuming ordinary days of mostly sunny with some cloud days. BUT, its not a perfect world so I would recommend you have a plan B in the form of a 2000 watt generator powering a modern reasonably high output converter which most rigs seem to come with nowadays anyway. (sorry, I don't know what your rig is, you may have a motorhome with a gennny built in) Even in the worst case sceenario of total cloud cover, running the generator for a couple hours per day will cover all the battery charger needs plus you can use it for higher loads at breakfast and supper like coffee makers, toasters, microwaves, Marguerite blenders, you, important stuff. :)
But here is something I recommend people to think about. Your residential fridge will use roughly what 10 incandescent light bulbs running 10 hours per day will use. Before you put any solar up on the roof I recommend that you change ALL OF YOUR INCANDESCENT LIGHT BULBS TO LED. This will save a ton of power. Then I recommend you STILL go ahead and put up 3 X 160 watt panels (or whatever equivalent configuration you choose) and then you are golden. Solar is relatively cheap these days, easy to install and low maintenance...or relatively NO maintenance. (I clean mine once a year unless I get a really hard rain, then I don't bother. When selecting the LEDS, don't go cheap (buy good quality) and buy the warm white colour type so that your interiour wood colours stay natural.
Hey, just noticing your handle, your not an old sabre flyer are you?
Hope this helps.
John and Angela
