SteveR58
Sep 26, 2013Explorer
RV Skylights
I am curious if anyone has used a flat Acrylic sheet in place of a skylight. I have a situation where I got a new to me RV that has some damage around one end of the skylight due to water intrusion an...
wny_pat wrote:Yes, you can still buy replacements and in fact there are a number of them that are acrylic as well. Just not flat. The problem is that I am going to use a bigger piece to cover a bigger area because of the damaged area of the wood on one side of the existing skylight. There is no way to repair the wood in the area without cutting the rubber roof and I am not going there. Sad that some people just let these problems continue to the point that it is to a point of damaging wood. Thanks pat
You can still buy replacement skylights that will fit in the same spot on your RV. In fact they are available at thru your local building supply stores.
