I am curious if anyone has used a flat Acrylic sheet in place of a skylight. I have a situation where I got a new to me RV that has some damage around one end of the skylight due to water intrusion an...
You should use Polycarbonate(lexan)as it won't shatter or crack if something were to hit it or someone were to jump on it. If you were to layer it for some insulation, you could use acrylic spaced under it.
