The best holding tank treatment available is
"Happy Campers"It's available from better RV supply stores, Amazon, Ebay and several dealers websites. Here's a link to one of those dealer's websites where you can learn more about it:
https://www.happycampersworld.com/
Amazon:
https://www.amazon.com/Happy-Campers-Organic-Holding-Treatment/dp/B007S0H5DUOne scoop per tank is all that's needed. Fill your toilet 3/4 full of water after flushing your tank, swish it around with your bowl brush, flush the toilet and fill it again with enough water to rinse the brush.
It was recommended to me by some Trek friends and I've been hooked ever since. We use Charmin Ultra tissue and don't have any problems with out tank sensor. It does a great job of killing the odors too.
Disclaimer - I have no connection to the company but when I find something that works, I share it with others.
With all that being said, nothing will ever be any better than flushing your black tank with a wand hooked to a hose and stuck down through the toilet. Blasting a good stream of water around the tank a couple times a years is a good practice that should be followed no matter what tank treatment is used.
