DFord wrote:
MetalGator wrote:
DFord wrote:
By adhering to recommended practices with every RV I've owned over the past 45 years, I've never had any issues with my sensors not reading properly.
So what are the recommended practices?
Read my previous posts in this post. Keep you dump valve closed till your tanks are at least 3/4 full. Never leave the dump valves open while your camping - sure recipe for problems. When you do dump, use the flush to refill the tank for a couple of minutes and repeat till the water runs clear. Twice a year use the wand to blast the sides of the tank. Use Happy Camper tank treatment in both the grey and black tank. I installed a flush kit on my grey water tank and it helps.
This is all excellent advice. However, Happy Camper is not necessary if you follow the rest of the steps. Happy Camper is the best odor killer I have ever used but it's not "necessary" to properly maintain your tanks.
