wa8yxm
Dec 18, 2018Explorer III
turbojimmy wrote:
This is the one I got. It was easy to install (if you're comfortable messing around with your breakers).
https://www.homedepot.com/p/Reliance-Controls-10-Circuit-30-Amp-Manual-Transfer-Switch-Kit-310CRK/205793178
THough not the EXACT one I used (Different arrangement of switches)
Close enough (Same concept) This is the type I recommend. Let me see if I can find the exact one I used..
Link to Lowes
This one is as close as I can get (the meters at the bottom were different else it's the same box) this is a 30 amp box Mine may have been heavier but frankly 30 amp was the size of the breaker I fed it with 30 amps at 120 volts times two legs that is. only used about half that to keep needed systems in house live. No washer or Dryer or central A/C but all lights save the indicator in the hall TV Kitchen computers and communications and Furnace. that's the biggie. If I have to live with fans to keep cool OK but if the pipes freeze MAJOR ISSUE
38,768 PostsLatest Activity: Jan 26, 2021
