topflite51
Nov 03, 2012Explorer
Tire inflation charts, according to the engineer, are the minimum pressure for the weight listed, his words. Can't remember the last time I saw a MH tire that showed signs of overinflation, but definitely have seen enough of them showing signs of underinflation.
The shock does not have to be wore out, it can simply be undersized for the job. I don't believe a shock has to be wore out to underperform. Have seen plenty of shocks that were wore out that showed no signs of leakage. As to Spartan's recommendation, I would take that with a grain of salt, if it were such a problem for them why is it that they deliver chassis' with GY's on them? If it is a problem and they deliver with GY's than shame on them. Not very responsible on their part is it? They should refuse to do so, bet they won't.
I am glad you are happy with your Mickey's and that they are performing well for you, but in case you haven't noticed there are a lot of people who will not run them for one reason or another. Doesn't mean all of them are bad, it just means that some have had bad luck with them. As I have said before consumers are a funny lot, it is never their fault, it is always the manufacturers. Have a good day.
