Don_Don
Nov 04, 2012Explorer
Thank you Topflite for all that good, logical information. Most I have said before as its never anyone's fault on here it always the product that fails. One reason you see so many Goodyears bashers on here as there are so many Goodyears on the road as its the tire of choice for most coach builders . By charts they all speak of I could run 100 lb in the fronts and 90 in the rear on my coach but run 115 in front and 110 in rear. Why do you want to be on the line? Letting pressure out does not improve your ride where it is noticeable. It's all in your head. One thing people don't realize is when you bounce up and down the road, you create more weight pushing down on those tires past what the coach weighs setting still. Don't believe that? Go jump up and down on a scale and you will see what i mean. I will always inflate 10 to 15 percent past what chats say for my load but never past cold pressure max on the tire. Never had a problem.....never.
38,781 PostsLatest Activity: Aug 12, 2026
