Mr.Mark wrote:
J-Rooster wrote:
With tropical storms getting ready to hit the Deep South, heavy rains 5-10 inches and extremely high winds, do or will you take your RV out for the Labor Day Weekend. I'm curious if there is any hard core RVers out there. I think I can handle the rain but, with the awning in, I would be worrying about damage to the slide toppers? Seems like this weather would be ideal for RVers without slides.
J-Rooster, you could be a RVer with no slides too..... just keep those babies in!
Our current coach does not have slide toppers, I don't miss them as they would vibrate in the wind. But, we have another problem, I have to make sure nothing large, like a stick, etc., falls on top of the slide-out as it could damage our air seals.
So, I guess it's a 50-50 thing..... Slide toppers could get damaged or things could fall on my slide tops. I have a mirror on an extended handle to check the tops before I pull them in. A couple of times, I've had to clean them off.
MM.
I hear you MM on the 50/50! Slides in wouldn't work for me with the DW, 2 dogs and a Parrot!
