Spizzer
Oct 14, 2013Explorer
06Fargo wrote:
If you don't turn the front wheels it will go straight in and straight out...
Paint 2 small black sight lines on the drive way that line up with the side of the coach that tell you that you are correctly lined up to taxi in.
And you would use the cameras for backing...
Parking in close quarters where you can see the wide points (mirrors) from the seat is easy but a little more clearance for the camera is a good idea.
Dangle a soft ball that touches the windshield when you are far enough in - saves someone accidentally kicking your stop board...
Don't back in - the big deezil will fill the house with fumage while you are making air psi's on start up.
and once you are in there post a picture on rv.net to get the kerfuffle going :) ... no wait already done :) :)
Can't keep the wheels the same. Once the driver mirror is through the door, I have to move a bit left to give the awning more clearance, and then follow the wall up as I move in.
The tennis ball is in work!
Thanks for the thoughts and ideas!
Jeff
