dougrainer
Jul 13, 2013Nomad
Francesca Knowles wrote:
I guess it's true to say that most Atwood tanks don't use an anode...but that's only because the tank IS the anode. It's all aluminum, which as a matter of fact is the most common material for anodes in home water heaters. An Atwood isn't lined with plastic, as some seem to believe. It will degrade over time by electrolysis, just as will any other metal.
Here's what Atwood's manual has to say about cathodic protection, and it's gibberish. "Clad aluminum protects against corrosion"???? What????Atwood wrote:
The tank has a clad aluminum lining that protects against corrosion and does not need to be replaced on a yearly or more frequent basis like anode rods do. A more detailed explanation of cladding is found in the back of this manual.
Gotta love that carefully parsed sentence about rods...it only says you don't have to replace the TANK as often as you'd have to replace a rod!
The further explanation one's directed to is more of the same. The tank's aluminum, folks, and electrolysis will eat it unless there's something lower-on-the-scale like magnesium present.
Atwood tanks will last a lifetime. Regardless of what this poster states. I have 34 years as an RV Tech and except for BURST tanks from Freeze damage, I have only replaced maybe 5 tanks in 34 years from internal corrosion. As long as you drain your tank at least twice a year and drain when NOT using the Water heater for months at a time, the Atwood Aluminum tank will last until the RV goes to the Junkyard. And YES, I have had to junk Atwoods when people install Hot Rods and install non plastic drain plugs because the metal in the plug they used has frozen the threads and you cannot remove the plug/Hot Rod to then drain for winterization or normal maintenance. Doug
38,766 PostsLatest Activity: Jan 10, 2026
