Posted: 01/11/07 07:30am Link | Print | Notify Moderator
This is from the installation instructions:
"Road Test & Adjustment: To ensure proper alignment and installation of the Safe-T-Plus unit, the vehicle should be road tested. Take along a socket wrench to fit the U-Bolts on the Tie Rod. While driving on a straight stretch of road, vehicle should easily follow a straight course, if not adjustment is necessary. To adjust; hold steering wheel in a STRAIGHTFORWARD position, stop vehicle, and set brakes. Loosen nuts on Tie Rod U-Bolts and allow unit to self center. (Frequently this movement is not noticeable). Retighten nuts and test drive again. Repeat this step if necessary until vehicle will hold a straight line. Note: You must hold the steering wheel in a straight forward position, with the engine running, until the adjustment has been completed. Otherwise the wheels will return to the pulling position instead of the straight-ahead position desired."
United Safety Apparatus, Co. (manufacturer of Safe-T-Plus)
Decatur, GA
1-800-872-7233
