jmccen58
Aug 17, 2014Explorer
Check out Harvard's extensive research and postings on the "Ford alignment" subject. He Knows what he's talking about. I've found that before buying anything new to add to the suspension, be sure you understand weight distribution, tire pressures and alignment settings. These must be correct before any "steering stabilizer" can do it's job. Once you get the 3 things set properly, you may find that you really didn't need the magic stabilizer. I,m at that point now. I have spent this summer addressing the above mentioned items and have achieved a marked improvement in the handling of my 32' E450. The last couple of trips of the season will determine if the "Safe-T-Plus" goes on this winter......my verdict is still undecided at this time....
38,782 PostsLatest Activity: Sep 10, 2026
