Have used the "Steer Safe" system on everything from a truck to a DP. Understand ONE THING, it will NOT cure a steering problem. It will help with passing vehicles pushing you and it will help you maintain control if a front wheel blows out, but that is it. It is a stabilizer, NOTHING more. Do I still use the Steer Safe system, you bet, but with the knowledge of its limitations, not as a cure all.
