- JerryofWVExplorerIf dual pane you might consider separating the panes and removing one, or taking it to a glass shop if you don't want to do it.
That way you can clean the single pane on each side. - wolfe10ExplorerIs this a dual pane (or is that pain) window that is fogged in the middle or single pane fogged on the inside?
If dual pane, which way are you headed-- there are repair places for this in Searcy AR and in Hudson, FL just north of Tampa, FL. - donfrumpExplorer
captpar wrote:
Drivers side window is fogged up ,can't see mirror need temp fix to drive safely to repair facility . Any ideas ?
try heating the window with a hair dryer till it clears up enough to see ok
38,705 PostsLatest Activity: Jan 22, 2025
