wjschill
Oct 20, 2021Explorer
Safety question
Any of you guys with Class A's ever use your leveling jacks to raise the rig for oil changes and tire replacements? I've heard of yes and no on both issues. Thanks, Skip
rlw999 wrote:Dutch_12078 wrote:
I can crawl under our gasser without the jacks deployed for an oil change, but raising the front a few inches gives me a little more elbow room. Since a failing jack in this case won't endanger me, I don't drag out the jack stands.
This still sounds like it could be unsafe -- if the jack fails suddenly, the suspension is going to compress a bit so if it was a tight fit before, it might be on top of you when it comes down. And it might be when you slid under a frame member to pick up the drain plug that rolled away... maybe you kicked the jack while you were scooting over and knocked off the hydraulic line.
