bennefim wrote:
I’m not familiar with “casters” or their settings. Would that be something that large trucking company could check/ repair?
Doug
Caster.. This is easiest to explain on a STRUT system popular on many modern cars.
This is zero caster >Direction of travel> |
this is positive /
And this is negative \
You are looking at the angle of the strut from the side of the vehicle.
In both cases it's never that much (Just a couple degrees) but the idea is positive caster tends to make the vehicle wish to go straight down the road and harder to turn.
Negative caster makes it very hard to control.
That said. the safety steer even with proper caster will help. And it really helps when TSHTF (a tire blows)
One other thing that may help is a trac bar or two (front and rear) I put one on teh front but I'm told rear is better if you use only one
What is a trac bar and why (Oh it's standard with Struts but most RV's have leaf springs.)
Springs are clearly for UP/Down movement but they can also be stressed side to side.
Imagine if you will the rear of the RV is swinging a bit to the right while the front swings left. YOU the driver see the rig as heading into the left lane and compensate. then the ends "Swap" and now you think you are headed to the ditch so you compensate. and they swap again so you go down the road like this ~~~~~~~
Well the trac bar, or pan-hard bar, LOCKS the body in position over the axle so it can not move side to side.. Now you go down the road like this ===================
