Tom/Barb wrote:
Bruce Brown wrote:
Take another look. There is clearly an extension slipped into the factory frame and welded. The extension failed right to the intersection of it and the factory frame. This one is on Thor.
I totally missed that the first go round. it shows the weld seam vertical to the crack.
I'd put this on Thor too. and possibility owner misuse. but it looks way to easy to overload.
I don't believe that is a welded extension at the break point.  Look closely; the vertical weld right at the end of the break is an L-bracket welded to the frame, not an intersection/joint.
