aksnowman wrote:
My brother started full timing this year and yesterday while disconnecting the Toad he noticed there was something wrong with the RV side of the tow receptacle. When he got underneath the back of the RV he found the tow hitch was bolted to the frame but that the frame had cracked where the two bolts are installed. The crack is about 4" long and if not discovered likely would have resulted in the separation of the Toad from the RV. I am to sure of the Model but the RV is a Thor product, 38' long and only a couple of years old.
I'd say that once it was welded up properly a four bolt L bracket would be in order for side bolting it to the frame, as well.
Need to look at mine again, to see how it was done.
