Samsung is an excellent choice. When considering which one to get be sure to measure for depth of the box as you don't want it sticking out in the room. I purchased a counter depth model which has a 24" deep box verses 31" allowing it to fit in your entrance door and fit your cabinet better. Most standard refers stick into the room to far. Samsung will also work with a modified sine wave inverter with no problems as incoming power is rectified to DC voltage and every thing runs on DC voltage. They are very efficient and draw less power than older units. I have the stainless steel double door 23.5 cu. ft. model with ice and water through the door and love it.
Blessings; Keith
