debbiebostonExplorerJan 01, 2015sani flush black water holding tankOur motorhome has a saniflush for the black water holding tank. Do you think using the fresh water hose on the saniflush would be safe as there is probably a backflow device on the saniflush?
coolmom42Explorer IIJan 01, 2015I would not use the same hose for the flush and for drinking water. No way. Even if there is a check valve, it can leak or fail.
Related ContentBlack tank flush overfillBlack Flush Anti-siphon ValveBlack Tank FlushBlack Tank FlushBlack Tank Flush
