naturist
Jun 05, 2017Nomad II
Dick_B wrote:
The drain should be directly below the FW Tank but it might require getting under the rig to find it. Mine is a small (1/2 inch or so) plastic pipe with a petcock (1/4 turn valve) on the end.
Mine consists of a hose hanging down with a pipe plug screwed in. To drain, unscrew the pipe plug. Talk about a cheap fitting!
I can't fathom having a water tank that can't be drained. What on earth would one do in freezing weather? So I'm sure there is a drain, somewhere. Finding it might be the issue. It should be noted that on the left side of my TT, at the very bottom edge of the side, is a sticker identifying where (a) the fresh water thank drain, (b) the water lines low point drains, and (c) where the gray and black water drains are located (as if you could miss the last of these).
