rk911
Jun 05, 2017Explorer
RTrider wrote:
Did a search and could not find my topic even though is likely discussed previously. Likely not using the right search criteria.
Anyway, .....
2009 Tiffan RED. Fresh water inlet fed from the rig water hose inlet through a two way valve. Meaning to fill the fresh water tank you simply change the valve to fresh water tank and it fills through the main system.
The tank has never been sanitized and we think we picked up some water that is not so good.
How do I get bleach into this closed system/tank?
A second related question is I cannot find the fresh water tank drain. I would hate to use the water pump to drain the tank. Where should I look.
Thanks for any help in this matter.
pour the bleach into the hose, connect the hose, flip the switch to TANK and turn on the water.
