luvlabs
Jun 05, 2017Explorer
The drain for the water tank will be in line with the water pick up line for the water pump. If there is no actual drain valve installed, you can remove the intake line for the water pump and let gravity do its job. You can add a T to that line and a valve and your future needs are met.
